Override Keyless entry
Old Oct 14, 2005 | 10:07 AM
GIJoeCam's Avatar
Originally Posted by svh7878
Well the stick on keypad definetly didn't work but I found a good deal on it and I have a few uses for it so i will install it anyway. Just made a spare key at the hardware store to keep in my wallet if I ever lose my key or lock them in it with it running again.
Another thing I've seen done is to take that spare key and hide it on the vehicle.... Use a stainless steel bolt, wing nut, and lock washer, drill a small hole somewhere under the truck, and wing-nut it in place, or.....
I've also seen people drill a hole in the key and run the license plate screw through it, sandwiching it between the plate and the bumper. Then, should you ever lock yourself out again, use a coin or screwdriver to unscrew the license plate bolt and free the key.
Those are my best suggestions....
-Joe
