high-beam switch
Old Sep 16, 2005 | 06:10 PM
jason77090's Avatar
high-beam switch
hey guys, got a question for ya... my 97 f150 is acting weird.. when i turn on my headlights, and push the switch forward to lock the lights on high beam, but they turn off... and also when i go to try to flash the lights.. i get nothing.. any suggestions would be great..
Jason
Old Sep 18, 2005 | 10:13 PM
jason77090's Avatar
if anyone has a suggestion, i would like it, cause i have to fix this issue in order to get my inspection... and i live right near the state trooper branch.. lmao
Old Sep 18, 2005 | 11:27 PM
RMS05's Avatar
Sounds like the relay that allows power to the high beams is bad.
Roger
Old Sep 19, 2005 | 08:37 PM
jason77090's Avatar
imma check the fuses as well.. but i will also look at the relays
thanks
jason
Old Sep 20, 2005 | 09:59 PM
jason77090's Avatar
in the 97 owners manual that i have.. i dont see a relay for the highbeams, is there any idea where it could be?
Old Oct 19, 2005 | 12:31 PM
cyucuis's Avatar
I'm having the same problem. No high beam lights with the switch forward. If I pull the high beam switch back I do get lights. I'm not getting any lights with the switch on the dash just parking lights. Any suggestions would help greatly.
98 F-150
Old Oct 19, 2005 | 01:51 PM
adrianspeeder's Avatar
The multifunction switch does go bad. This is cropping up in the 92-93-94s due to age.
Adrianspeeder
Old Oct 31, 2005 | 10:08 PM
gino_007's Avatar
im having the same problem with my 02 supercrew, i checked the fuses and they seem fine....any other suggestions
Old Nov 1, 2005 | 09:50 PM
Bobzilla's Avatar
Like adrianspeeder said they do go bad. I had to replace my stalk because I was getting a little tired of wiggling it to get my washers to work and to have the turn signals come on steadily. Replaced it and all is well
