Autolamp/O.D. button dead
Old Aug 2, 2005 | 06:14 AM
MN-Riverrat's Avatar
On my SuperCrew 4x4 5.4 the autolamps and O.D. funtions do not work. All other normal headlights / high beams / fog lamps work properly once **** is turned, but nothing on the autolamps.
And my O.D. button does not come on....ever. It's always on
Would these two items be connected? All known fuses seem fine and not blown. Any suggestions?
Old Sep 3, 2005 | 07:28 PM
jetnjmy's Avatar
Same problem
I am having the same problem. I have found that fuse #29 under the steering column is blown when this happens. It is a 5 amp fuse and when replaced everything works. I do not know why it is blown all the time but if you come up with anything let me know.
