Cruise Stopped Working
Old Jun 25, 2005 | 10:30 AM
firmin72397's Avatar
Question Cruise Stopped Working
I have a '98 F-150 4.6 and for the last couple of weeks the cruise has been acting strange. Sometimes I can set it with no problem but a few miles down the road it will just kick off. Then I can't reset it without turning it back on. Other times it won't let me activate it at all. After I pump the brakes a couple of times it seems to work but still drops out later on down the road. I've replaced the master cylinder switch and right now I have it jumped out so I'm fairly certain this is not my problem. Any suggestions?
Old Jun 25, 2005 | 12:59 PM
lewis_ice's Avatar
Question Maybe
I don't know if your truck falls under the recall senerio or not, but that maybe your problem. If not, sorry no help here.
Old Jun 26, 2005 | 12:00 AM
mkinttrim's Avatar
I'd carry a fire extinguisher if I were you!
Old Jun 28, 2005 | 03:09 PM
GIJoeCam's Avatar
His is not one of the currently recalled ones, but that's a likely indication of a failing brake pressure switch, the same one that is in the currently recalled vehicles. I'd suggest disconnecting it, picking up the replacement switch, and doing an install ASAP. -Joe
