Power Door Locks
Old Apr 25, 2005 | 07:46 AM
cdawley's Avatar
Power Door Locks
I have a 1999 f-150. Both driver and passanger power door locks have stopped working using the button and the keyless entry. The locks will seem to try and actuate but rarely fully actuate. I can put the vehicle in Drive and the passenger side will auto-lock. The drivers side has to be manually pushed down. I can also press the button and hear the clicking sound of the locks but not sure if that is the relay making that noise or the actuators trying to work. I have taken the doors apart and looked at the actuators, but it looks like the actuator and door lock assembly built into one. Is that correct also? Does anyone have any suggestions?
Thanks,
Chris
Old Apr 25, 2005 | 09:56 AM
cdawley's Avatar
I have been reading the threads and everything looks like it is the actuators. Mine looks like it is part of the lock assembly. Is that correct? Where is the cheapest place for me to get new actuators? Dealerships in my area want 55-60 bucks for new one. Would cost about 110-120 bucks for both.
Thanks,
Chris
Old Apr 30, 2006 | 11:15 PM
tridentboomer's Avatar
Would you mind shareing with me the steps necessary to remove the door panels. I gave up after a short time. If I get my locks to work I will share the information with you.
BTW my truck is a '99 F-150 XLT with extended cab.
Old May 1, 2006 | 07:48 PM
colglfr's Avatar
This link in the fourm
This provides the details in removing ad adding acutators. I need to do this myself.
https://www.f150online.com/forums/sh...=door+actuator
Good luck
Old May 28, 2006 | 10:44 PM
Power door locks don't work
I had the same problem with my '99 Ford F-150 and fixed it. I will not take credit for ths fix as I read it here or another forum. The problem is a thermister which is a small rectangler piece of metal and is mounted in the motor which in turn is mounted in the actuator. It is a little tricky removing the actuator but can be done. Once you get it out pry it open ( you will bust the little tabs that hold it togeather but not to worry as a little epoxi where the tabs were will hold it togeather when finished. Once you get it apart, remove the motor and reshape the bent tabs that hold it togeather and disassemble the motor. Inside the motor you will find the thermister. Pry it out and wrap it in foil to short is out thus eliminating it from the circuit. Put it all back togeather and wolla you now have working door locks. If you want prove it before reassembling it in the truck hook two small clip leads up to the actuator and hook one to your already disconnected battery (hope you thought of doing this before doning anything else) and then touch the other clip lead to the other battery post. If you don't see the actuator try to move reverse the clip leads on the battery or actuator. after wrapping the thermister in foil and reassembling it thy this again. You will be amazed at the results. Any questions you can leave it here or to my direct e-mail (probley smarter) and I will get back to you. Good luck....Bill.
My e-mail address is ab0ot@juno.com
