a bad short
Old Feb 22, 2005 | 09:42 PM
sprayingsmooth's Avatar
a bad short
i have a short some where in my system the blinker fuse blows as soon as i turn the key on i even tried a bigger fuse and it still blowes my abs light also has been on too i have been told that the abs the speed sensor the over head temp and the blinkers all tie into the same am i right or wrong any help would be much appreciated and i have recently put new rotars and brakes up front if that helps any thanks
Old Feb 22, 2005 | 09:57 PM
lees99f150's Avatar
which fuse is blowing? there are a couple of fuses in the turn signal system.
Old Feb 22, 2005 | 10:03 PM
IT IS #28
Old Feb 22, 2005 | 10:06 PM
MY BAD SORRY IT IS #23
Old Feb 22, 2005 | 10:21 PM
lees99f150's Avatar
#23 feeds the flasher block and the multi function switch. There have been problems with the wiring in the steering column. Move the tilt wheel up or down and see if it changes and doesnt blow. If so, do a search here for more info on the column.
You can also take out the trailer charge relay to isolate that if you have the 7 pin trailer plug. here is a link for the tow relay
Old Feb 22, 2005 | 10:56 PM
I MOVED THE STEERING WHEEL DOWN AND IT WORKED THE ABS LIGHT EVEN CAME OFF BUT WHEN I PUT MY BLINKER TO TURN LEFT IT BLEW THE FUSE IS THERE ANY THING I CAN DO TO FIX IT ANY HELP WOULD BE GREAT
Old Feb 22, 2005 | 11:13 PM
lees99f150's Avatar
Read this post and see if it helps. Also you can use the search feature
There have been alot of posts on this problem.
