Help! 99F150
Old Jan 22, 2005 | 10:01 PM
jaydubbleu's Avatar
Unhappy Help! 99F150
Just bought 1st truck, used 99f150XL. No manual yet (dealer ordering it). Theft light flashes. Is there a security system in it? Also, would like to add additional map light up front. Any experts out there?
Also, driver door loose...can hear air. They tried to fix. Any suggestions? I am taking it back next weekend.
Old Jan 23, 2005 | 07:38 AM
projectSHO89's Avatar
You can download a pdf version of your manual free from www.fleet.ford.com Look under the MAINTENANCE tab.
Steve
Old Jan 23, 2005 | 09:40 AM
jhogan's Avatar
The theft light flashing means your security system is working. It is not an alarm. Your key has a chip in it, when you put it in your ignition the truck recognizes the key and allows you to start the it.
If you went to your local hardware store and had a key cut, that key would allow you to open your doors, but you would not be able to start the truck. Hopefully you received two keys with your truck because having a spare key programed with only one original key is expensive.
With my 99 truck, if I did not shut the door firmly, basically slam it, then I would get a wind noise while driving. I would just pull over and slam the door. That would take care of the noise.
Old Jan 23, 2005 | 07:33 PM
jaydubbleu's Avatar
Thanks for the responses!
