headlight switch
Old Jan 17, 2005 | 06:06 PM
bonehead's Avatar
Angry headlight switch
I recently replaced the headlight switch in my 1994 F-150 because the dash lights would not come on without some extensive playing with the position of the switch. Replacing the switch has made no difference. Has anyone had this problem before and what was the fix?
Old Jan 17, 2005 | 10:10 PM
chucks bp's Avatar
If mamory seves me right I believe ther are two fuses that supply powe to the headlight switch. Get a test light and check all the fuses I think you will find one that is burnt out, I believe there is a circuit breaker to supply the headlights only. Hope this helps!
