Alarm System Reset
Old Dec 1, 2004 | 07:17 PM
amatxshark's Avatar
Alarm System Reset
I recently diconnected my neg battery cable to reset a check engine light that was caused by a loose gas cap. Since then my alarm system is all out of wack. When I try and use the keyless entry pad the system goes off before I can even get the second number pushed ......anybody know what could be causing this?....and if so, suggestions to clear it....It appears to be a VSS System#6
Old Dec 3, 2004 | 12:20 AM
TonyPTX's Avatar
Re: Alarm System Reset
If you have a VSS system then you need to set the "Entry Delay" option to ON....it's under Option Bank #3. See the attached link PDF for instructions on how to put your system into programming mode and then setting your options accourding to the right table for your alarm system...
Tony
Ford PowerCode System Programming
