Pass. Airbag Switch Pics
Guys,
My airbag light is flashing then staying on. After doing some reading, and knowing the previous owner had some stereo equipment in the truck, I pulled the center panel to check out the plug for the passenger airbag switch. This is what I found. I need some pictures of how it's suppose to look since it appears mine is broken/damaged.
This is the plug I found hanging in the back of the dash...
Sorry you're not getting much help. I know you probably don't want to hear this, but I would recommend you take it into a dealer. Messing with anything related to airbags can be dangerous and expensive if something goes wrong. If the light is on, then something is not working properly. If you mess with the connectors/wiring and it shorts, you could set off the bag causing injury to yourself. Also, to replace an airbag is a couple grand. If you leave it in its current condition, it might not deploy in an accident. So, for the safety of your passangers, you should get it fixed.
