Replacement headlight switch for fogs
Old Aug 5, 2004 | 09:34 PM
tj_03supercrew's Avatar
I'm looking into adding fog lights to my 03' supercrew. I would like to get the factory headlight switch that will operate the fogs as well. Is this possible? Has anyone else done it, and do you possibly have the part number for the switch?
Any info appreciated!
Old Aug 6, 2004 | 07:21 AM
Jag's Avatar
Jag
You can look up the part # on:
www.motorcraft.com
I purchased one from www.rockauto.com. Thay seem to be cheaper than buying parts from a dealer.
Old Aug 6, 2004 | 09:42 AM
J-150's Avatar
the **** and swicth are already set up for the fog-lighht pull-out (if you tug on the one you have now you will see this)
i believe you only need a new wiring harness behind that switch.
there is a current thread on this (can't remember which forum) so a quich search should get it for you.
good luck
