Keyless Entry Problem
I want to change the key code on my 01 screw. in the manual it only says how to add a code. I want only one code and not the one that was given to me in the factory. Does any body know how to change the factory set keycode. Thanks
Matt
Matt
Replace the RAP / CSM ( mfgr date Dependant as to which it is ).
The factory code is actually ( correctly ) called the permanent code, only changing the module out can change it.
Sorry for the bad news.
