Air Bag Code 46
Old May 11, 2004 | 11:41 AM
Whizzer's Avatar
Air Bag Code 46
I have a 2002 F150 XL flashing Code 46 on the Air bag warning light The bags look ok no damage on the Truck.
Old May 11, 2004 | 10:29 PM
STAN/SRMASTER's Avatar
LFC 46/DTC B1877/B1885 — DRIVER PRETENSIONER CIRCUIT RESISTANCE HIGH OR LOW. Air bag systems have a 5yr/ 50,000 mile warranty. Do a visual inspection of the wiring running up to the drivers pretensioner(seat buckle) under the divers seat.If you don't see anything I would recommend a trip to the ford dealer.
Old May 12, 2004 | 02:59 AM
Mr_Bentwrench's Avatar
i've seen the little yellow connectors under the seats get wet from people when they sprayout their interior or steam clean the carpet. and sometimes they get a loose connection from the seat moving back and forth.
thats just acouple quick things to check anymore then that and you would have to disable the air bags and install "simulators" to test the system safely without the chance of accedental deployment.
Old May 27, 2004 | 01:50 PM
cflet's Avatar
02 F150 Airbag light
What did you find out about your airbag? My light just started coming on and blinking yesterday. Where do I find the codes to find out what my issue is? I just went over 50,000 on my truck. The first thing to to wrong.
Old May 31, 2004 | 10:42 PM
RogerD's Avatar
I had an airbag code a few months back but I don't recall the code number. Not 46, I assume. I did find that the little lightbulb in the airbag on/ff switch was burned out. Went to an electronics store and bought a little 12v bulb with leads and replaced myself. Required some soldering.
Roger
