Battery Indicator on Dash ????
Old Apr 22, 2004 | 09:10 PM
txpakrat's Avatar
Question Battery Indicator on Dash ????
Hi, Just found this board. I am hoping that someone here can help me!
I just bought a '97 F150 Supercab 4x2. The truck is in cherry condition, but has 175k miles. It runs great, however, when I accelerate hard (like passing someone on the highway), the "battery" indicator on the dash flickers on and off.
Is this a problem that I should be worried about? A possible problem with the voltage regulator or alternator? Maybe a cable loose somewhere?
TIA
Bob
txpakrat
Old Apr 22, 2004 | 10:57 PM
Yankee7985's Avatar
Could be your serpentine belt has stretched or your alternator is on the way out.
Old Apr 23, 2004 | 06:38 AM
txpakrat's Avatar
Yankee,
Thanks for the info. I had the truck serviced when I picked it up. They replaced the serpentine belt.
Could it be slipping? Incorrect tension?
Thanks,
Bob
Txpakrat
Old Apr 24, 2004 | 06:47 PM
JMC's Avatar
JMC
25 Year Member
If they replaced the belt it is most likely not slipping. The light indicates a problem with the alternator. I beleive that parts stores will test the alternator for free.
Regards
Jean Marc Chartier
Old Apr 24, 2004 | 09:41 PM
txpakrat's Avatar
Thanks!
If it gets worse, I'll pull it see if that is the problem.
Bob
txpakrat
