Keyless Entry Question
Old Apr 12, 2004 | 01:13 PM
drrarick's Avatar
My father has a 2000 F-150 that he bought used from a local dealer. He THINKS the truck has keyless entry, but he didn't get remotes when he bought the truck.
I'd like to get him a remote or two for his birthday - does anyone know how I can tell for sure if the truck has keyless entry?
I appreciate the help! Thanks!
Old Apr 12, 2004 | 09:32 PM
B-Man's Avatar
Cool
I found this thread when I was working on my truck several months ago...
and it worked !!
Old Apr 14, 2004 | 08:49 AM
drrarick's Avatar
Thanks very much for the information. It's looking like the truck does not have remote locks.
I tried turning the key to run 8 times, as described in the linked post, and nothing happened. I also looked for a white box by the parking brake, and I didn't see one.
It funny, because I looked at the owner's manual, and the manual specifically states that the truck is equipped with remote locks. The manual does not give instructions for programming the locks, however, as the linked post stated it would. Instead, the manual says that the remotes must (and can only be) programmed by the dealer.
And I was wrong, the truck is a 1999, not a 2000.
Old Apr 15, 2004 | 01:33 AM
Mr_Bentwrench's Avatar
hmmm the remote programming procedure is ussually in the owners manual and the key program procedure if you have 2 programmed working keys. but if you only have one key then it is a dealer key programming procedure.
Old Apr 15, 2004 | 08:21 PM
lees99f150's Avatar
when you do the key turn 8 times make sure you do it very fast. when i tried mine i wasnt doing it fast enough
Old Apr 15, 2004 | 08:59 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
drrarick, that is a great idea.
Father's Day will be here in a couple of months.
Just before Christmas I borrowed my wife's van took it to Circuit City and had a Remote Starter installed for $100. We already had two remote entry fobs and the remote starter is now a third one. All that is required is power door locks. I think all XLTs had those. They did the job in under two hours.
The remote starter is great on those cold mornings, the vehicle will run for ten minutes.
