03 Explorer Wiring Help
Wiring Help; if you have an 03 EVTM CD, please read
If anyone here has an EVTM for an 03 Explorer, I NEED your help.
I am trying to install MUTH Signal Mirrors in an 03 Explorer and the wires they tell me to use are not there.
I need to locate the turn only wires for the right and left turn signals IN THE CAB of the vehicle in the door sill(s). They are there, but I cannot figure out which wire color combo or where they are.
I am about ready to bring wires up into the cab from the tails to finish this project because I am sick of searching for these elusive wires.
I will be eternally gratefult o anyone who can help me out with this.
I am a visual learner, scans and photos are encouraged if applicable.
Looking at the wiring diagram a white/lightblue is right front turn and a lightgreen/white is left front turn. Both wires can be located in connector 263.This is a gray connector with 74 pins. It is located under drivers side dash.The wires you need are in the middle of the connector pins 43&44.BE SURE TO TEST THESE WITH A TEST LIGHT OR VOLT METER , EVEN GOOD WIRING DIAGRAMS CAN BE WRONG.Good luck.
Thanks for the information. The big grey 74 wire connector gives me a lot more to go on. I was looking in the wire looms rather than way up in the connectors. I'll have to go have a look see this weekend and see if I can find that.
Thats teh wire colors they give me, but they couldn't give me any idea where to find them.
Thanks again!
Thanks again!
