how to program keyfobs?
Old Feb 16, 2004 | 09:19 AM
njemt's Avatar
How can I re-program a keyfob in a 1999 f150?
I purchaced a used one, i don't have the ones that came w/ the truck. thanks
Old Feb 16, 2004 | 11:38 AM
GPFAPAGE's Avatar
USUALLY ALL YOU HAVE TO DO IS PUT A KEY IN THE IGNITION AND CYCLE THE IT FROM THE OFF POSITION TO THE RUN POSITION (WHEN THE RADIO IS ON BUT THE CAR ISN'T STARTED) EIGHT TIME IN TEN SECONDS. YOUR LOCKS SHOULD CYCLE TO LET YOU KNOW THAT IT IS READY TO PROGRAM. THEN YOU JUST PRESS ONE OF THE BUTTONS ON THE REMOTE AND IT SHOULD WORK. IF YOU HAVE A SECOND REMOTE, THEN JUST PRESS A BUTTON ON IT RIGHT AFTER YOU DO THE FIRST ONE.
Old Feb 16, 2004 | 11:37 PM
Pestco1's Avatar
Turn ign on, push and hold button under dash until horn churps three times. push and hold button on remote until horn churps once. should be it if it is a factory set up. Keep in mind thatyou can only program a max of 5 remotes. Then you have some special procedure to erase the old ones.
Old Feb 17, 2004 | 12:22 PM
njemt's Avatar
Where is the button located?
Where is the button under the dash?
Old Feb 24, 2004 | 10:45 AM
buschman's Avatar
The procedure outlined by GPFAPAGE is correct for the OEM remote keyless entry system. Try that one first.
The method Pestco1 is describing is for an aftermarket system - likely installed by a Ford dealer.
Old Feb 24, 2004 | 01:35 PM
SSCULLY's Avatar
Could be my memory fading, but I thought once you entered programming mode, that you needed to have all of the remotes that you want programed, as it starts over from zero.
I'll look for Jeff Law's post on it, if I find it I'll post back, but be aware that this might happen. ??
Old Feb 24, 2004 | 01:44 PM
SSCULLY's Avatar
Here they are :
https://www.f150online.com/forums/sh...threadid=83829
Originally posted by kidtriton
remotes= make sure you do all the ones you want to work at the same time. Cycle the key from off to run eight times, ending in run the eighth time. The locks should cycle. Press any button on tramsmitter, locks should cycle. Press any button on second, third, fourth.... trans., locks should cycle. Turn key to off position. All transmitters you just programmed should work, all previous transmitters not done that time will no longer work.
http://www.fordf150.net/howto/reprogramremotes.php
