Excursion Key Pad Code ( Location )
Old Feb 12, 2004 | 05:23 AM
rajuncajun37's Avatar
Where is the 5 digit code located, i found mine on my 2003 F150 under the dash , but i bought a 2000 Excursion for the wife and can't find it.
Thanks, Mark keller
Old Feb 15, 2004 | 11:08 AM
lees99f150's Avatar
a friend of mine needs to find the code for his explorer sport does he need to take it to the dealer for the code
Old Feb 17, 2004 | 11:01 AM
buschman's Avatar
In both cases the dealer can easily use a test tool to provide the 5-digit number.
What model year is the Sport Trac? I'll try to pull up the location of the security module...
Old Feb 17, 2004 | 12:09 PM
fordman3's Avatar
rajuncajun37,
Don't know if this will help, but on a '99 Explorer Limited, the code is on the top of the computer, which is located in the left inner rear panel. On it, if I removed the cover for the jack and handle and looked up inside and kinda pulled the panel back, I was able to see it. I bought my Explorer used and the previous owner had never used the programmable locks and had no idea what the code was. I saw a 5-digit number on the computer and tried it and voila! Then I was able to program my own code, but it still retains its original code, too. Hope this helps. Later.
Old Feb 17, 2004 | 05:52 PM
fordman3
someone else said the same thing, i looked but could not locate, i will try again
Old Feb 17, 2004 | 06:38 PM
I looked in the back behind the jack, found a black box 2x4 inches with this info:
Excursion
YC3T-15K866_BA
VALEO
PN 250.487A
MATL: PA6-BK
4 X 2
0770E
Is this the Security Box???
Old Feb 20, 2004 | 11:02 PM
lees99f150's Avatar
buschman
it's a 2001 sport trac
thanks for any info
Old Feb 24, 2004 | 10:33 AM
buschman's Avatar
The Security Module (Central Security Module) for the 2001 Sport Trac is located behind the passenger-side airbag. If you're not comfortable removing the airbag then go to your dealer - they can pull it up with a diagnostic tool.
For the 2000 Excursion the Security Module (Generic Electronic Module) is located under the dash, to the left of the steering column.
