looking for a switch...
Old Jan 12, 2004 | 08:43 PM
closer9's Avatar
I'm not sure what they're called. They're used for hoods, doors, trunks, and the like. Basically a small stud that when pressed either breaks or makes the circuit...
I've looked at stores around here, but can't find any...
thanks...
Old Jan 12, 2004 | 08:59 PM
Invalid_access's Avatar
Have you looked at radio shack. They have tons of switches.
Old Jan 12, 2004 | 09:01 PM
Ted'98's Avatar
I think this is what you are looking for.
Pin Switch
Old Jan 12, 2004 | 10:06 PM
closer9's Avatar
Pin Switch
That's exactly it! Thanks...
Yes, I looked at Radio shack, but didn't see anything there. The RS here is kinda small, and not always stocked real good...
Old Jan 12, 2004 | 11:11 PM
B-Man's Avatar
Cool
Hey closer -
What are you going to use the switches for ?
I might have something that will work better, depending on what you want to do...
Old Jan 13, 2004 | 06:05 AM
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
A place that installs/sells auto car starters/alarms will have them.
Old Jan 13, 2004 | 08:19 AM
closer9's Avatar
Originally posted by B-Man
Hey closer -
I'm putting lights in the bed (under toneau), and I plan on putting two switchings a rocker and a pin switch as a safety precation to make sure the lights can't come on if the top is down...
Old Jan 13, 2004 | 09:37 PM
Rockpick's Avatar
Moderator &
I believe you'll want NORMALLY OPEN switches rather than NORMALLY CLOSED then...
Radio Shack does sell some (however, they might not be exactly what you want) as I purchased a couple there when I did my auto-light in my console.
Old Jan 13, 2004 | 10:53 PM
closer9's Avatar
No actually normally closed. I want the circuit closed (complete) when the lid is up, which is the "normal" position for the switch...
Old Jan 18, 2004 | 01:01 PM
GIJoeCam's Avatar
NC will work
I used a normally closed switch on Skagel's lid. Worked like a charm.
-Joe
Old Jan 18, 2004 | 07:53 PM
JMC's Avatar
JMC
25 Year Member
Get a Switch like the one used under the hood. When it is up it is on and when it is down it is off. No drilling, no fuss, no muss.
Regards
Jean Marc Chartier
