Staic in CB with engine running
Old Dec 24, 2003 | 05:51 AM
je3169's Avatar
Hey all i have a new midland CB(77-120 ESP)and every where i go for power i get noise i went to the batt with both pos and neg that didn't work went to fuse box still got noise tryed 2 different noise filters still noise now i grounded at the brace under the black cover on the center hump and taped onto the power point next to the lighter still got engine static as for antenna i have a firestik II on a SS L bracket mounted to the inside top of the bed rail on the drivers side and i ran a ground from the bracket in threw the vent with the coax and grounded it to the cab any input would be great.
TIA John
Old Dec 24, 2003 | 08:57 AM
Florida-150's Avatar
Did you happen to run the coax anywhere near the power cable? You need to seperate the power and coax if they are near each other very much. Other power sources could effect the antennae wire as well like if you have a power wire running to an amp or something similar. Just a thought...
Old Dec 24, 2003 | 09:03 AM
je3169's Avatar
they run next to each other under the seat about 6"
John
Old Dec 24, 2003 | 10:29 AM
TerryK67's Avatar
it sound slike a ground problem to me....here is a idea..
After you have verified that the antenna is properly grounded to the chassis or frame (not to the battery), the next step is to include an additional ground from the chassis of the radio to a good metal ground within the vehicle. (Note: This is not the power ground but a separate chassis ground). To do this, loosen a screw from the side or back of the radio, connect a wire to this point and re-tighten the screw. Attach the other end of the wire to a known good ground. If a power amplifier is used, it also should have a separate chassis ground wire as described above, installed. Remember to keep both the radio and the amplifier ground wires as short as possible.
If this doesnt work it might be a bad coax cable....let me know and goosd luck!!
Old Dec 24, 2003 | 02:01 PM
je3169's Avatar
thanks i will give that a try
John
Old Dec 24, 2003 | 07:55 PM
Pickup Man's Avatar
I get static on mine like crazy, I hear the wipers, the windows, the power seat, and the engine. I thought it was just normal to have static.
Old Dec 28, 2003 | 09:34 PM
je3169's Avatar
Ok after grounding the case it seems to have fixed my problem thanks for the help.
John
Old Dec 28, 2003 | 09:53 PM
TerryK67's Avatar
Glad it worked!!
Old Jan 18, 2004 | 01:56 PM
masssheltie's Avatar
Ford Fuel Pumps are notorious for spewing hash in the HF section of the radio bank (0 - 30 mhz). Ford even sells a filter that can be installed across the terminals of the fuel pump to reduce the hash.
