window motor going out?
Old Dec 12, 2003 | 12:24 PM
my97offroad's Avatar
Seems like my pass. side window gets slower and slower especially when its cold out. What the deal with this issue? anyone else have this problem?
Old Dec 12, 2003 | 03:45 PM
veazie1's Avatar
I have the same problem on my '98. In fact, about once a month, the window gets stuck in the fully up position. I replaced the window regulator but it got stuck soon after the replacement. I did learn that there is a big coil spring (not cylindrical but like a pancake) that gets wound as the window goes down. This spring likely helps raise the window taking some of the load off the motor. I would imagine that this coil of steel is gets harder in the cold weather making the window go down slower. Just a thought.
Old Dec 12, 2003 | 11:21 PM
Old Timer's Avatar
Did you try "search" There were numerous reports/fixes on exactly what your asking.
Good luck...OT
btw..if they got weeded out, look for updates here.
