hazards problem
Old Nov 1, 2003 | 02:08 AM
Johngs's Avatar
hazards problem
When I turn on my hazards the only light that actually flashes is the front passenger side light. On the instrument panel its the same, only the right arrow blinks.
Also it blinks "faster" than normal...
Could it just be a fuse? Im pretty sure it isnt the bulbs since they work fine otherwise...
Old Nov 1, 2003 | 04:00 PM
Johngs's Avatar
bump?
Old Nov 1, 2003 | 11:12 PM
Pestco1's Avatar
If you have turn sigs at all four corners then I would change the flasher.
Old Nov 5, 2003 | 08:29 PM
J-150's Avatar
could also be the beginning stages of the multifunction switch ready to fail.
If you notice that your turn signals start acting wonky then it probably is the multifunction switch.
Old Nov 5, 2003 | 09:11 PM
Johngs's Avatar
I figured out it was the hazard switch. When I push it, sometimes if I jiggle it the hazards all work properly.
Also, the times when only the one light is working, I can hear a sort of scratching sound when the blinker blinks. Its wierd.
But I figure the switch for the hazards is bad (the noise I hear comes from the steering wheel).
J-150 - where is this multifunction switch?
