Battery Light/Battery Overcharge
Old Oct 16, 2003 | 02:29 PM
javierruizleon's Avatar
The battery Light on the wifes Expedition stays on, but everything works fine. I took the battery to get checked and the guy said the battery is overcharged. The battery is a year old. Is this a Voltage Regulator or Alternator problem? Thanks in advance.
Old Oct 18, 2003 | 03:44 PM
It was the Alternator by the way. I bought the Voltage Regulator first, not that. So I bought the Alternator, fixed problem. Hope this helps someone in the future.
Old Oct 22, 2003 | 01:01 PM
UPDATE! The "new" alternator I installed was bad! Got a replacement and everything looks good. Advice: Whenever getting a new part, if possible, have them check it before you install it. Saves time and money.
Old Oct 22, 2003 | 10:16 PM
speedy46's Avatar
Registered User
must just be this time of year, I too am having to have my alternator replaced. I also posted asking for information only I did get 1 helpful response. Good luck with the second alternator.
Speedy
Old Oct 22, 2003 | 10:50 PM
Did you need any help? It was easy going in and out using the Chilton Book.
Old Oct 23, 2003 | 01:24 AM
Pestco1's Avatar
Great advice about having the new part checked out. Can't tell you how many times I have installed a new part only to have it be just as bad as the old one. Especally important with electrical as some places will give you a hard time bringing them back thinking that something else is wrong and it broke their new part.
