Lock-Unlock wires location
Old Sep 19, 2003 | 11:37 PM
Proud Veteran's Avatar
Question Lock-Unlock wires location
Are they in the drivers kick panel or passenger side?
Old Sep 20, 2003 | 02:27 AM
SSCULLY's Avatar
For the "main" button, or the power to the individual switches ?
The reason I ask, I don't know if you are looking for the control / switch lead or the power to the system.
It starts up behind the fuse box as a common point, maybe that is what you are after ?
The truck with remote entry and / or the keypad, the unlock is the driver's door only, then all doors. This is from the GEM I think ( or the RAP / what ever the new name of it is ).
If you post which one you are looking for ( all / driver's / pass, or power ) that would be helpful.
Old Sep 20, 2003 | 02:42 AM
cgorris's Avatar
You can get wire color codes for connecting an alarm from the following website.
www.bulldogsecurity.com
If you want the wires to connect an additional door lock actuator to you can find the pink/blk and grey wires that voltage reverse (lock and unlock respectively) in the passenger side kick right where the wires come into the truck from the doors.
You can also check out my gallery. I have pics posted of where they are in the passenger side kick.
