A/C blows cold air for a few minutes and then switches to hot.
Old Sep 14, 2003 | 10:53 AM
chonky150's Avatar
Hi,
I just noticed that my A/C when set to the coolest setting will blow cold air for a few minutes and then blows hot air. Another thing I noticed is that when the cold air is blowing and I am at a stop, it immediately switches to hot when I take off. I am also unable to switch to hot/cold on the temperature selector. Does anyone know what may be causing this? Any info would be greatly appreciated.
Thanks,
C
Old Apr 10, 2004 | 10:58 PM
bobk538447's Avatar
What fixed it?
Old Apr 12, 2004 | 11:01 AM
turboted's Avatar
chonky150; It sounds like you may need to have the clutch on the compressor reshimed to allow it to engage correctly, the
no switching could be a vacuume leak or broken cable to the heat
control. LIVE LONG AND PROSPER. .TURBO TED
Old Apr 12, 2004 | 06:26 PM
swyatt's Avatar
The same thing is happening to mine. What fixed it?
Old Apr 13, 2004 | 02:46 AM
Mr_Bentwrench's Avatar
it could be the electric motor that operates the blend door.
and i ve seen plenums that crack where the blend door mounts and it gets stuck. then you have to pull dash and replace plenum.
Old Apr 13, 2004 | 11:08 PM
FordMasterTech's Avatar
what year model/make?
Manual or Automatic (digital) controls?
I will help you figure out what's wrong with it
Old Apr 14, 2004 | 06:03 AM
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
sounds vaccuum related to me.
Old Apr 15, 2004 | 01:29 AM
the only thing in the climate control that is controled by vacuum is the defrost vent and floor doors. the heat/cool blend door is electrically controlled by a motor.
