AM Radio noise
AM Radio noise
My 1994 F-150 has AM static with the Key in the "on" position but no static with the key in the "acc" position without the engine running. With the engine running you can hear noise from the ignition system. Is the PCM causing this? What can be done to eliminate the noise?
Could be ststic from the fuel pump KOEO. the pump should only run and cause interference for a few seconds. There are also plenty of other electrical actuators running KOEO. IAC, TAB and TAD, ETC. I am sure it is not anything too serious
