Headlight troubles
Old May 17, 2003 | 03:06 PM
okstormchaser's Avatar
Question Headlight troubles
I have a 97 F-150,....A few weeks ago the low beam headlights would not come on when I turned them on. I could flash the bright lights and the low would then come on and stay on. Now the high and low are out and the only way I can get any light is to pull back on the high beam flash at the turn signal. Tried new bulbs and new headlight switch....Anybody got any advice?
Old May 18, 2003 | 05:05 PM
FordMasterTech's Avatar
Check your connectors at the multi-function switch (turn signal switch). If connectors do not have any pins pushed out, then you are probably looking at a bad multi-function switch.
It's not that big of a deal to swap out.
If the connector looks ok but you are reluctant to replace the switch, let me know and we will go from there.
I'll help you in any way that I can.
Good Luck
FordMasterTech
