Fog lights
Old Apr 25, 2003 | 07:35 PM
rnash's Avatar
Fog lights
I have a 1999 F150 XLT and want to switch the fog lights on seperatly with a different switch. Is there anyone that knows which wires to short at the headlight switch connector ?
Old Apr 25, 2003 | 11:42 PM
pw1981's Avatar
Re: Fog lights
Yup, just not me
Sorry, its late and I stood out in the sun all day.
Old Apr 26, 2003 | 08:36 PM
FordMasterTech's Avatar
That would be pin 5 circuit 275 that is Yellow in color..
apply 12 volts with a jumper wire to confirm before snipping it though..
One tip:
If using a tap from the fuse panel.. use on that is hot in accessory or run, so that you don't run your battery down. Because by removing this circuit from the headlamp switch, you will not get any warning of the lights being on, and I don't think the battery saver relay will turn it off either..
Good Luck and let me know how you do!!!
FordMasterTech
Old Apr 26, 2003 | 11:35 PM
rnash's Avatar
fog light mod
It was suggested to me to pull the yellow wire to ground with a switch, because thats what the main switch does. This way the indicator light on the main switch will go on also when the second switch is turned on. What do you think ?
Old Apr 27, 2003 | 03:04 PM
according to the wiring diagram, placing a ground on the yellow wire will not activate the fog lamp relay..
You will need to place 12volts on the yellow for the fog lamps to work..
Keep me posted
FordMasterTech
Old Apr 27, 2003 | 07:19 PM
rnash's Avatar
fog lamps
FlowmaterTech.......... Thanks for your aswer and I'll try what you suggested. Sounds good. Thanks again......... Rick
Old Apr 30, 2003 | 08:10 PM
rod150's Avatar
Take a look at
http://www.geocities.com/tedoca/headlight.html
this worked for me.
