busted trailer plug receiver
Old Apr 22, 2003 | 09:24 PM
dantheman1973's Avatar
Unhappy busted trailer plug receiver
Hey guys,
I noticed that my trailer plug receiver is busted...
Previous owner must have backed over something...
It was all bent under... the plastic is all cracked and busted, and that little spring loaded door is broken off...
It was Ford factory installed...
Any suggestions on repair/replacement.. without having to cut any wires? I would really like to keep everything OEM if possible.
Dan
Old Apr 22, 2003 | 09:41 PM
Home skillet's Avatar
Ford sells just the connector.
Old Apr 23, 2003 | 07:20 PM
That might solve the problem..
I am going to check to make sure the connector that's there still works..
First it's an eyesore...
Second, I know I could get dirt/mud/roadgrime up in it (without the little spring door).
Thanks again
Dan
Old Apr 25, 2003 | 04:04 PM
Old Timer's Avatar
Hey Dan
You'll get more than dirt etc if the contacts ground out
Just get the replacement part...to rewire it is actually rather simple. Just pay attention to which wire goes where. Just look at old plug..rewire same way to new one..just dont do backwards like i once did. Really..its easy to do..if not paying attention.
Good luck...OT
