HELP! How do I get to the Fuse Box?
Old Apr 21, 2003 | 02:20 PM
RajunCajun2001's Avatar
While I was checking a fuse in the fuse box, I must have somehow pushed the connector back into the fuse box or broke it. When I try to put the fuse back in the slot, it falls right out. There is nothing in the slot holding the fuse.
How do I get to the inside of the fuse box? Remove the fuse box?
Any help is appreciated. Thanks!
Old Apr 21, 2003 | 07:38 PM
Old Timer's Avatar
Hi Rajun
Which fuse box? I dont know about inside one...but on my 99..fuse box (under hood) was removable. As i recall there were some kind of clips holding it in place. Not the top.. but the body.
For me there was enough play to flip it around to check bottom side..i was tracing wires at the time..so that helped me to see bottom side. I assume holder came loose or broke???
If its inside panel...it had to go in..so it should come out?
May/maynot help?
Good luck....OT
Old Apr 22, 2003 | 11:37 AM
2stroked's Avatar
This may sound silly, but I had the exact same problem once and it turned out I was trying to put the fuse back in the wrong slot. (Several are not used and do not have contacts.) Try that first.
Old Apr 22, 2003 | 12:00 PM
Its the fuse box in the cab, and its the right slot.
