Fule Pump Fuse
Old Mar 19, 2003 | 11:39 AM
F150 dad's Avatar
Fule Pump Fuse
I have a 98 f150 with the 4.6, just bought the micro tuner and now I need to remove the fule pump fuse. As with most preowned trucks I have no owners manual, so I am not sure witch fuse it is. If you know please help, Thanks
Old Mar 19, 2003 | 01:17 PM
flafonman's Avatar
Hey dad how are you?
The fuse you want is in the box under the hood, not the one in the cab. It is fuse 19 (20A).
The links are to two threads I did a while back that may help you out.
Fuses
Fuses
Good Luck
Old Mar 19, 2003 | 01:56 PM
stantd1's Avatar
Pull the cover off the underhood fuse box and there should be a label telling which fuse is which.
