Electric Door Lock keep blowing fuses
Old Mar 15, 2003 | 10:16 PM
kb2763's Avatar
My 1997 F 150 blows the 15 amp fuse each time the door lock are operated. Anyone have a suggestion on how to trouble shoot this problem?? Truck had an after market alarm that has been disconnected to door locks.
Old Mar 16, 2003 | 08:04 PM
B-Man's Avatar
Cool
kb2763 -
I would disconnect the lock harness from both doors. Operate the locks. If the fuse blows, the issue is in the wiring before the doors.
If the fuse doesn't blow, reconnect 1 door and try. Process of elimination should isolate the door causing the problem.
Did you remove the alarm or did someone else? Maybe a wire was left that is shorting the locking circuit to ground...
Good luck...
