97 F150 XLT with prewired fog lights
I have a 97 F150 XLT that's 2 wheel drive and does not have factory fog lights,though after looking at it I've found that it apears it has the wiring for the lights. I have two fog lights mounted on lightbar and haven't wired them up yet and now I have the idea to hook them up with the factory wiring. My problem is that after testing with a volt meter, it's not getting any power. I'm relatively sure the fuse and relay are there. Is there something else that needs to be done to get it to work?
Hi - have you seen this post? https://www.f150online.com/forums/sh...hreadid=107860
It might help or might if other posts are made. I'd be interested in what you find - I'm about to order the right and left side lights from http://www.autobodypartswholesale.com - they are $67 each.
Good luck - MZ
Good luck - MZ
