Calling Mike T. or others knowledgable
Old Oct 10, 2002 | 04:12 PM
02XLT's Avatar
Question Calling Mike T. or others knowledgable
Mike/Anyone,
I am thinking of purchasing a nice shift kit and sonnax valves to firm up my trucks shifting. My question to you is the following: If I order a superchip can it be programmed to just take out the shift delays/retards and NOT increase the line pressure? Thanks for yuor time and help.
-Brian
Old Oct 10, 2002 | 07:56 PM
GearHead_1's Avatar
Yes, it can be programmed just as you described. I believe however that it will cost you a little extra to have a "custom" burn. I have a SuperChip and Transgo and though I can live with it shifting hard. I am having the chip reburned to accomidate other mods and am planning to soften up the shifts slightly.
Old Oct 11, 2002 | 12:40 AM
beastie's Avatar
Did you install the shift kit on level 1?
Old Oct 11, 2002 | 09:43 AM
GearHead_1's Avatar
No, went to level 2.
Old Oct 11, 2002 | 01:14 PM
Former Sponsor
Hi Brian,
Sure, we can take care of that for you.
There are a number of modifications people are doing to their transmissions that results in shifts that are too hard, jerking passenger's necks even at very light throttle, etc., such as installing a shift kit at a level that is too high, or aftermarket valve bodies, etc.
We can also supply you with the shift kit, Sonnax parts, etc., in fact we're having Sonnax build a part designed to our specs for the 4R100 tranny right now, so we work with them, too.
You might want to give us a call about this & go over exactly what kind of shift characteristics you want, as we can advise you on how best to achieve what you're looking for in most cases.
