ECU code question for Mike
Old Mar 15, 2002 | 01:42 PM
drm7's Avatar
I found a white sticker near the hinges on the driver door, like you said it would be. It had 2 codes, 1 tiny code in top left corner of sticker that said 3L30, and 1 large, bold code that took up most of the sticker that said "KID1". Is KID1 a valid code? If so I've found what I need to fill out the order.
Thanks!
Old Mar 15, 2002 | 01:50 PM
kschaper's Avatar
The bigger one is the code for the computer. It is also on the computer itself if you take off the black clip.
Old Mar 16, 2002 | 01:11 PM
Former Sponsor
Hi drm7,
Yes, you've found it, glad your code sticker was still intact! KID1 is indeed a valid code, and is readily available.
