Bad ECU?
Bad ECU?
i have a 07 f150 5.4 with a edge evolution. just replaced the plugs and packs on it. then i got codes for cam sensor, replaced those, trouble codes still come on. took to ford dealer he said after three days of working on it it looked liked the ECU has gone bad. now im getting a number 1 cylinder misfire. has anybody ever had anything like this happen? does it sound like the ECU? also one more thing the misfire only happens when the truck temp is cold. if you let it warm up before driving no problems other than the can sensor trouble codes. the mechanic thanks the programmer is a fault!
So, do you notice any problems with the truck in the stock tune? If not, the PCM is fine, but there is something else that needs adjusting/replacing. Even if you DO still see problems, I'd look for them anywhere BUT the PCM, since the truck runs.
When you replaced the plugs and COPs, what brands did you use?
- Jack
