adjusting tune with SCT
I'm having a ping issue and want to retard the spark a little.
When I go into the spark settings they are listed from -14 down to 0.
My question is, are the values that are displayed going to set the timing to that value or adjust it from what is already set into the program?
For example, if you choose "0" it will have the timing commanded by the tune with no changes. If you choose "-2" it will pull 2 degrees from whatever is commanded.
Hope that helps.
Bob
