Edge Spark Knock
Old Mar 2, 2013 | 02:42 PM
NgtvNrg's Avatar
Edge Spark Knock
I am having a problem with my Edge Evo programmer. When it is set to Lvl 2 I get a spark knock when getting back into the gas while coasting. It doesn't happen on the other levels or in neutral. (I haven't tried Lvl 3) I have tried using 89 octane fuel and it still happens. The truck is a 2003 4.6 with no mods, and the only setting I have changed are tire size and gear ratio. Does anyone have any ideas on how to fix this?
Old Mar 2, 2013 | 02:55 PM
Veteran: Army
so it has no mods, yet you modded the truck???
yes, get a tuning device that's worthwhile
Old Mar 2, 2013 | 03:09 PM
That's highly unusual, especially with the 4.6. Usually when this happens, it's with an aftermarket intake. I think your best bet is to call Edge. You could reduce the timing a little, but if running 89 does not make a difference, reducing the timing probably won't either.
Old Mar 2, 2013 | 03:20 PM
NgtvNrg's Avatar
[QUOTE=tarajerame;4960194]so it has no mods, yet you modded the truck???
I guess I really don't consider changing tire sizes a "mod". For the gear ratio, it was changed because the Edge showed a different value then the door sticker.
Old Mar 2, 2013 | 05:09 PM
JackandJanet's Avatar
I agree with Jim about the spark knock. I wonder if you have some carbon buildup? High heat range plugs might cause this too.
The Tire Size and Gear Ratio are wrong because Edge uses "placeholder values" for them when you open the Custom Options Menu. If you simply say "no" to the custom options choice, the Evolution will load factory values from the VID section of the PCM, which should give you the Gear Ratio that is installed in the truck and the OEM tire size. There's no real way to use the Evolution to "check" your tire size or gear ratio.
- Jack
Old Mar 3, 2013 | 12:00 AM
NgtvNrg's Avatar
Would carbon buildup cause it to knock only on Level 2? I treated the motor with seafoam not long ago to see if it cured it. I will have to check on the plugs.
Old Mar 3, 2013 | 11:35 AM
Level 2 uses an enhanced fueling strategy and I think the spark is advanced a bit. Either of these could cause pre-ignition if your truck is close to that point already. You COULD try retarding the spark just a bit (try -0.25) in the custom options to see if that helps. As Bluejay said though, that's somewhat like trying 89 octane fuel, which you've already tried. Still, it won't hurt to experiment.
I've read mixed reviews on Seafoam. I don't recommend using it.
- Jack
Old Mar 3, 2013 | 01:40 PM
My guess is your using crappy gas.. Go Fill up at a Chevron or Shell Station with supreme if you have one around you..Id also get a few bottles of Techron fuel cleaner and dump a couple bottles in there for a tank.. I bet it will clear up
Old Mar 3, 2013 | 03:20 PM
NgtvNrg's Avatar
I have been using Chevron or Texaco 89 for about the last 5 tanks so I really don't think it's a fuel issue. While researching Techron I found this:
Originally Posted by 2fords
Giving it gas at a low rpm's in too high of a gear can cause a ping also, try dropping down a gear.
Could this be the problem?
Old Mar 3, 2013 | 03:39 PM
If it pings under those conditions when running 89, you are running too lean. It should be able to handle some strain without pinging unless you are way under geared. How tall are your tires?
Old Mar 3, 2013 | 03:45 PM
Another thought. Does it ping on when you return to the stock tune? Of not, then something is wrong with that level 2 tune. Level 2 is actually supposed to be a little rich for towing.
Old Mar 3, 2013 | 09:24 PM
NgtvNrg's Avatar
The tires are 285/70r17. It doesn't knock on Level 1 or 0(factory), only on Level 2.
Old Mar 4, 2013 | 06:20 PM
JuddFX4's Avatar
Try updating the edge with the newest version my old truck had the same problem when i updated the programmer it went away. might be worth a try.?
Posted from F150online.com App for Android
Old Mar 5, 2013 | 09:35 AM
Have you tried the highest octane available there (91-93)?
Old Mar 5, 2013 | 09:07 PM
NgtvNrg's Avatar
I have tried updating it, and it says there are no updates available. I have not tried 91 octane, but according to the manual you are supposed to be able to run Level 2 on 87.
