Need some programmer/tire size/speedometer help!
Old Nov 28, 2012 | 10:23 PM
LonestarROB's Avatar
So I've got my truck lifted, gears and bigger tires and tune from Bill(PHP). Problem is, the speedo is still waay off. I've tried adjusting it but can't get it dialed in. Contacted Bill but haven't gotten a response from him.
Anybody help me out? Recommend any setting to try?
I have 35" Trail Grapplers. 35x12.50.18 . 35.04 is the official overall dimensions .
Rob
Old Nov 28, 2012 | 10:31 PM
Adjust it in small increments to dial it in. The best way is to use a GPS, you want the programmer speed to match the GPS speed. If you don't have a GPS or can't borrow one, you can use an Android smartphone with an app. When dialed in, the speedo will probably read about 2 mph high.
Old Nov 28, 2012 | 11:12 PM
Yea, I'm using the GPS in my dashboard. It's about 5mph lower then what the speedo says. I think it's set to 35x12.00.18 right now. What should I try? Do I go bigger or smaller?
Old Nov 29, 2012 | 12:17 AM
Ignore the speedo - match the GPS to the tuning device. Experiment with bigger and smaller.
Old Nov 29, 2012 | 11:54 AM
Edit - Nvm.
Old Nov 29, 2012 | 04:38 PM
JackandJanet's Avatar
Rob, I don't recall what kind of programmer you have, but if it's a CS or CTS, try setting the diameter to 34.0".
- Jack
Old Nov 29, 2012 | 04:58 PM
- Jack
Hey Jack,
Yea I have a CS. Earlier I found where you suggested 33.9-34.0 to someone on the PHP forum. 33.9 worked for me. Thanks!
Can you take a look at my post(PHP forum) and bring it to the attention of Bill or give your opinion? Would GREATLY appreciate it!
Rob
Old Nov 29, 2012 | 07:07 PM
Originally Posted by LonestarROB
Hey Jack,
Rob
Rob, it's really hard to get Bill, due to the ongoing difficulties he's having with Edge's Fusion app overwriting his custom tunes. From your description, I think it's quite possible your tunes were overwritten with the canned tunes. This is the way we used to be able to tell:
Go to [Help]->[Product Info] on the CS/CTS. If you see a "Calibration Version" that looks like n.nnnn.nnn where the four "n's" in the middle are NOT ALL zeros, you DO NOT have custom calibrations. If the "Calibration Version" looks like "n.0000.nnn", you DO have custom tunes on your CS/CTS and any connection to Fusion is going to replace those custom tunes with canned ones (even if your firmware was already up to date)!.
Bill is able to tell for sure by looking at the Fusion server history. He can tell what happened when you last connected. But, this is a somewhat time consuming process for him which keeps him from writing tunes.
- Jack
Old Nov 29, 2012 | 09:43 PM
Thanks again Jack.
Under Calibration Version, mine says 3.5785.2900.
What do you think about the gears setting? Bill obviously didn't adjust them or put them in incorrectly. He was supposed to adjust them to 4.56 but they were set to 3.75. I changed them to 4.56 myself but, maybe its me, but it feels a litttle bit more sluggish. Should I change it back to 3.75? Leave it 4.56? Jump off a bridge? ......
Old Nov 29, 2012 | 10:23 PM
Thanks again Jack.
According to your calibration, you are using canned tunes. So, any gear and tire size that Bill put in your tunes has been wiped out too.
You gear ratio should ALWAYS be set to the axle ratio you have installed - in your case, 4.56, so, set the GR that way. If the TS of 33.9" corrects your speedometer, leave it set that way too.
If it feels sluggish, it's possibly because you are using canned tunes instead of custom tunes.
You're going to have to get Bill to reload your custom tunes on to the Fusion server, and you're going to have to hope that Edge doesn't put some flaky little firmware update on too, which will wipe those custom tunes out again.
This is why PHP has decided to stop offering custom tuning for the CS and CTS. They have no control over the way Edge uses Fusion.
- Jack
Old Nov 30, 2012 | 12:08 AM
Argh! Ok, thanks for the help Jack. Guess I'll give Bill a call in the morning.
Old Dec 3, 2012 | 10:35 PM
Veteran: Army
have you considered a re-gear???
Old Dec 4, 2012 | 08:32 AM
I did. 4.56 G2's.
