Edge VIN locked
Edge VIN locked
I put my edge in a 2003 F-150 after setting my 97 back to stock, it fried the PCM so I replaced it, I'd like to put the tune back on my 97 but it says its VIN locked. I couldn't set it back to stock prior to pulling it out of the 03 so I was wondering if y'all might know what needs to be done
Wes
Wes
Wes
Wes
either way, my suggestion is to take it as a sign and get yourself a device without cable issues and a custom tune all at once
I don't know that it has to be "sent" to Edge to be unlocked. I THINK they may be able to unlock it remotely, but there will be a fee - I think it's around $75, but I may be wrong.
- Jack
- Jack
Which would be one that doesn't have cable issues?
I'll give them a call when I get a chance to get it squared away, I've been workin so much that they're always closed when I finally get the chance to call them up
If you want the gages go with Edge Gryphon +CS/CTS, only draw back is PHP is only choice for custom tunes. SCT X3 is program and remove, but there are several good tuning shops that will write custom tunes.
