Is the display worth the xtra coin?
Old Aug 8, 2012 | 07:40 PM
klhmn's Avatar
Looking at tuner from Troyer with customs tunes, X3 Power Flash Drive or would you spend the xtra and get the Livewire with the display? This is for a 2010 F150 5.4 4x4
http://www.troyerperformance.com/cgi...chips%3BFoMoCo
Old Aug 10, 2012 | 04:47 AM
2009KR's Avatar
I have the Gryphon / Edge CTS and definitely like the display. It is the only way to see my engine and trans temperatures. I tow nearly 4 tons, so this is important to me.
The factory gauges are really warning lights with arms. My engine temp gauge doesn't move from 180 degrees to at least 235 degrees (the hottest I have run). I'm not sure what temp it jumps to the right. Similar with the trans temp gauge.
Old Aug 10, 2012 | 01:59 PM
JackandJanet's Avatar
^^^What he said^^^
I tow also, so I want to see my trans temp, my cylinder head temp and my alternator voltage. Additionally, the display will show you any engine and transmission codes that are thrown and will allow you to clear them if you can fix the cause.
- Jack
