Edge CTS...Can I use level 3 wt 89 octane
I was wondering can I use level 3 on my edge CTS while running 89 octane safely. Maybe by backing of the timing and if so how much. If it helps with your decision I have E3 spark plugs and 100lbs injectors set to 40lbs if that makes a difference.
To add to this - Bill at PHP has advised against running lower octane gas in a 91 octane performance tune, even if you DO retard the spark timing. He's said there is more to a high octane tune than just a timing advance.
I would not do it.
- Jack
I would not do it.
- Jack
Also, how many miles on those E3 plugs. Other members here have had a lot of trouble with those in the 3v engines.
