chassis control module
Old Mar 14, 2012 | 11:51 AM
6Jeff6's Avatar
Well company called and said they could not fix it! Great...
Old Mar 20, 2012 | 07:10 PM
5point5's Avatar
Just went through the same problem (March 2012). Seems the Ford Engineers designed the GEM to attach to the dash right under the windshield, and designed the windshield to leak--according to a bunch of posts I have read. And because there are about a gizillion GEM's out there--and it must be the correct one-(exactly), you have a problem. The current market on the item makes them pricy--(97 and 98 are the same in 2wd and 4wd but must match the equipment--power windows 6 cyl, along with the same options) Mine is a F75B-14B205-LB. Tough for an old geezer like me (69) to climb under the dash , but I pulled mine out and carefully inspected it and cleaned and lightly sanded all the contacts. I saw nothing wrong and no broken wires or loose connections. I put it back together and re-installed and everything works. Might be worth a try.
