Innovate to SCT
Innovate to SCT
Anyone here done it? reading through some of the how to articles it doesn't make sense. Everyone says you need a serial to USB adapter....for what? the 9 pin get wired to the LC-1 and plugged into the XCal2, then just XCal2 goes to the OBDII and the printer USB cable to the laptop. what am I missing?
Don't mind me, just making notes to myself, and others in the future.
http://www.classictiger.com/mustang/...cal2Wiring.pdf
Originally Posted by MGDfan
Anyways...
Yep, read through both of those already. In the innovate article it says you need a USB to Serial adapter, but then never says what you need it for in the article. I understand the rest and seems like the wiring is complete without the adapter. Was just asking if I was missing something.
Well, I guess my question is what plugs into the adapter? Or into the serial port on the computer?
The 9 pin mini din cable gets cut and wired to the LC-1, then the other end plugged into the XCal2
The Printer USB goes from the XCal2 to the computer
There is no serial cable to hook up....
A little lean?
Mine is hard wired, installed years ago, but doesn't Innovate make a 9 pin/usb adapter?
