sct computer code?
Old Aug 10, 2011 | 06:31 PM
archangel2003's Avatar
sct computer code?
ok im trying to order a custom tune from vmp. i have an sct sf3 tuner. and im not sure what the computer code is that the site is asking for.
Old Aug 10, 2011 | 07:01 PM
JackandJanet's Avatar
I'm not positive what VMP wants either. But, I know he can write tunes using your PCM's "box" code, which you find on a label on the PCM itself. This will not give you a tune that's as good as one you would order with the PCM's "hex" or "calibration" code, which uniquely identifies the actual stock tune that's loaded in the PCM.
I THINK, there is some way to retrieve the "hex"/"calibration" code (it goes by both names) using the SCT programmer though. Check your owner's manual for how to get it. It should be a 7-character code that looks something like mine, which is: "RXCM5E4" (yours will be different).
If you call Justin, he can probably tell you how to get him what he needs if you can't figure it out yourself.
- Jack
Old Aug 10, 2011 | 07:11 PM
http://www.sctflash.com/PDF/X3_SF3Manual.pdf
Top of Page#8
Plug it in the the obdll port.
Wait for it to boot up.
Use arrow down once and highlight "vehicle info."
Push "select"
It should be there or the might be another menu leading you to it.
Old Aug 10, 2011 | 08:14 PM
Top of Page#8
Push "select"
Good post, 88!
(I like your new sig, too!!!) I doubt anyone will complain about the fact that it's "slightly oversized".
- Jack
Old Aug 10, 2011 | 08:29 PM
Good post, 88!
- Jack
thanks!
Old Aug 15, 2011 | 08:50 PM
finally got it all figured out and got my tunes in the truck, vmp did a great job on them.
Old Aug 15, 2011 | 09:06 PM
