louder rev on key turn over?
not sure if it possible but i have 04 supercrew with an edge evo and was wondering if there was a setting to alow a louder turn over .i noticed some other trucks sound like there is alot of pressure built up and released on turn over.
might be a stupid question but im sure some one might have a NON SARCASTIC OR SMART A$$ ANWSER
thx- dave
thx- dave
I know what you are referring to, but I don't find it that impressive. It is possible to have the engine rev up more when you start, but it can't be adjusted with a hand held programmer. The pcm is programmed to initiate the start at ~ 400 rpms when turning over and allows a set amount of cranking air and fuel which is adjusted per a table using the trucks CHT temp. The crank_air could be increased by your tuner to have that quick rev.
