Uh Oh! Mike
Old Jul 10, 2001 | 07:16 PM
RAM AIR's Avatar
Unhappy Uh Oh! Mike
Hi Mike,
I just read the thread about the 160 thermostat. Know what? I never took my 160 out when I switched from the hypertech to the superchip. Sounds to me I made a big no-no. So without delay, I'm gonna change the stat. Now, should I just get a factory 180 or no. Seen what you posted, just want to double check . Funny, I forgot all about that damn thing. I never thought 20 degrees would make that much of a difference. I know heat makes power, but also thought heat kills. Well, go figure. As always, still learning at 38. Man it's never ending is it. I still haven't handed in my mid-term paper from 23 years ago. Think I passed? As always, Thanks Mike. Take care. Talk to you later.
Old Jul 10, 2001 | 08:22 PM
Neal's Avatar
Cool
HI!... F-150RAMAIR : The factory thermastat is 192-194 degree's. So if you are currently running a 160 degree stat then your almost 34 degree's colder! When you switch back, make sure you get a factory stat. They are extremely accurate and some of the aftermarket satst can be let's say rated at 190 but open at 175. So go factory stat. Hope this helps you out.
Old Jul 10, 2001 | 08:46 PM
RAM AIR's Avatar
Thanks Neal, wasn't sure. I forgot all about that stat. Back to stock we go. Coming from you Neal. I know it's right. Thanks buddy.
Old Jul 11, 2001 | 09:16 AM
BuffaloZone's Avatar
(Changed Subject ... Oops!)
Mike,
I know this has been mentioned a lot, but I was wondering if you could "adjust" my Superchip for me ... if possible?
My chip seems to be working pretty sweetly, but my speed-limiter still kicks in at about 95 MPH
Just wondering if you could raise the limit, or remove it? Thanks!
BTW, the computer code is: BIK2
Old Jul 11, 2001 | 11:24 AM
Fritzthecat's Avatar
Hey Buffalozone, I have a BIK2 chip and I've exceeded 105 on several occasions. Weird we have the same code since my F150 is different than yours in gearing.
Fritz
Old Jul 11, 2001 | 03:06 PM
Former Sponsor
Hi Ram Air,
Well, sometimes you just forget, you're only human, and as hectic as most peoples lives are these days chasing the almighty buck it's no wonder!
Just replace it with the factory thermostat, and you'll be set!
Old Jul 16, 2001 | 05:03 PM
Re: (Changed Subject ... Oops!) Here we go again...
Originally posted by BuffaloZone
Mike,
Mike, you didn't answer ... but I did get your Email. Funny that you didn't know who I was, when I was replying to the "Thank You" Email that you sent me. I even attached your original letter ... with my order number and everything...
Anyway, I'm not sure what to make of your response ... can you "fix" the limiter, or not? And, when I bought the Superchip, was it *supposed* to already have the limiter removed? If, so, than it appears that the chip didn't remove the limiter, because my limit is *still* 95 MPH with ... or without the Superchip. Also, no ... I haven't changed my tires and wheels, it still has the "factory" Lariat 17" Wheels and 275/60R-17" tires. Still has the factory gears, too. BTW, before you ask, I still use 93 Octane Texaco.
Thanks in advance ... I would appreciate any help you could give.
Old Jul 16, 2001 | 08:11 PM
> Generally speaking, I can tell you
> that the BIK2 code does in fact
> have the top speed limiter
> removed, it's always had that
> removed.
So, my speedometer shouldn't **still** read 95 MPH ... just like it did, without your chip, right?
> There was a thread just posted on
> F-150 Online about this, where
> someone said they were still
> shutting down at 95 mph (which is
> below the actual top speed limiter
> shut-off point of 98 mph), so
> something else is going on if that
> was you.
No, there's nothing wrong ... except that the "limiter" is still *not* removed. BTW ... hate to say it, but it almost sounds like you're making excuses, because you've mentioned many times, that the "factory set" limit just might not translate perfectly to the speedometer, because the speedometers aren't 100% accurate; that accounts for the 3 MPH "something else is going on", that you mentioned.
> There was also a response in that
> same thread from another BIK2
> Superchip owner, who verified that
> the top speed limiter is in fact
> removed,
Yes, his needle moved more when he used your chip, but mine did not.
> as he posted being able
> to hit over 105 mph, clearly
> proving that the 98 mph top speed
> limiter is in fact gone in the
> BIK2-code Superchip.
So I guess that proves that my Superchip, in fact, is defective.
Thanks...
Old Jul 16, 2001 | 10:56 PM
Former Sponsor
Buffalo,
You know, ordinarily, we're happy to help just about anyone, in just about any way we possibly can.
I have no idea why you are conducting yourself in this manner, but since you seem to think that posting my private email communications to you on the Internet is ethical conduct (it's not, and don't ever do that again, you do not have my permission to do so), if you want assistance from us, you will have to pick up the phone and call me, just as your Superchip documentation tells you to do if you have any kind of problem, and I'll be more than happy to talk to you personally.
Just so we're crystal-clear, there will be no more communications here on these message boards about this between you and I, nor in email. If you want assistance from us of any kind, you can pick up the phone and call us. We're here Monday thru Friday from 10am to 7pm Eastern time.
The ball is in your court.
