shift points????
Old May 13, 2011 | 05:24 PM
jbrd23's Avatar
shift points????
just got hypertech programmer. What do I set the shift points for each gear and rev limiter at for best results???/
Old May 13, 2011 | 05:57 PM
Hypertech Suppo's Avatar
Former Sponsor
Hypertech Max Energy Programmer
Raise the shift points + 300 rpms on 1-2, 2-3 & 3-4 shift points. Set your rev limiter to + 500 rpms. This will get you up in the rpm band so you can get the power gain of 35HP 42TQ on the 87 octane tune.
Old May 13, 2011 | 06:43 PM
2010fx4's Avatar
So high how will the rpm's get at full throttle before it shifts? I have a 2010 F150 with a 5.4L and hypertech max energy as well.
Old May 14, 2011 | 01:59 PM
Can you even change the shift points with the 6 speed?
Old May 14, 2011 | 06:46 PM
jbrd23's Avatar
Ok thanx hypertech support. I will try that.
Old May 14, 2011 | 09:31 PM
RandomHero34's Avatar
if you dont know exactly what you are doing, i recommend leaving the shift points alone. My friend decided to start messing with the shift points and ended up trashing his tranny. Just my 2 cents.
