Can XCal3 reprogram speedometer?
Old Apr 18, 2011 | 10:31 PM
aggieben04's Avatar
I have one tuned by VMP and I switched to larger wheels and tires. Is there a way to recalibrate the speedometer?
Old Apr 19, 2011 | 02:45 PM
Nutty 5.0's Avatar
Yes, I know on my Xcal3 I have the choice of gear ratio and/or tire revolutions per mile. Obviously the Revs per mile is what you want to adjust to your correct tire size accordingly.
Old Apr 19, 2011 | 02:52 PM
yep
Old Apr 19, 2011 | 06:31 PM
aggieben04's Avatar
Thanks I'll check it out
Old Apr 19, 2011 | 07:54 PM
http://www.sctflash.com/PDF/3000-3015%20small.pdf
Old Apr 19, 2011 | 08:27 PM
JackandJanet's Avatar
To the OP - you did not tell us the model year of your truck. If it's an old one (pre-2000), the X3 may not be able to do it. If the PCM is not in the loop, you'll have to change the gearing of the Vehicle Speed Sensor (VSS).
I can never remember when the PCM was brought into the picture. I'm thinking it was 1999, but my rapidly fading brain cells are not helping much. :o
- Jack
Old Apr 19, 2011 | 08:52 PM
aggieben04's Avatar
Sorry, it's an '07
Old Apr 19, 2011 | 10:14 PM
ONELOWF's Avatar
- Jack
Brain cell loss or not, you are correct. 1999. 97' - 98' require the vss gear change and custom tuning to get the speedo correct.
Old Apr 19, 2011 | 10:23 PM
Thanks, ONELOWF! Appreciate you not giving me the "idiot" treatment.
To the OP, with an 07, you are good to go with the X3. 88Racing gave you the correct guidance. Just look for the appropriate menu in the device.
- Jack
