Ping issues
It's running lean! Get that thing off there before you do some serious damage. The pinging is predetenation from bad ignition timing.
x2, not sure what fuel you are running, that could be part of the problem, but probably not the end all solution. A higher octane will help predetenation, but if its as bad (noticeable) as you stated it will probably not be enough to compensate. See if you can call superchips about this, not familiar with their programmers but you may be able to changing timing to a safe range/value.
Your not by chance running Level 3 on 87 octane are you?
haha, I did not know other people used that - during college I worked doing IT work and we used that phrase all the time ID-10-T.
Make sure you're running the right octane gas for the tune and if that's not the problem contact whomever you bought it from and put it back to stock immediately......
